New Car Needed. Advice Welcome!
Yeah. Electric Handbrake, Full LED lights, Bigger infotainment screen, wireless charging for phone. Although that last one seems to be only if you get the connectivity box which isn't as standard. What I don't get though is Android Auto / Apple Car Play have to use a USB cable. So Full Link is stanrd but doesn't actually work unless you get the connectivity box :s
Annoyingly it's enough for me to want the 2017 model over the 2016.
Android Auto needs the cable as the phone essentially drives the car display, it just wouldn't work well over Bluetooth.
If I was buying one new I'd want DSG and the winter pack. LED illumination pack is a no-brainer too. Although now I'm looking at the website, it doesn't look like auto lights and wipers are standard now so I'd want those as well.
Yeah I get that but then why is the USB port not standard even though Full Link is? So the infotainment is capable of Android Auto but if you don't purchase the connectivity box then you can't make use of it.
LED Illumination comes as part of the convenience pack I believe which adds auto wipers, auto dimming rear mirror and lights.
Out of interest why is everyone recommending a Leon over a Golf? Theyre the same underneath aren't they? Is a Golf just overpaying for the brand?
