Tether WiFi on KitKat
Are you tethering via USB?
I dont think you can tether wirelessly to the phone and then use the phones WiFi connection also.
I'm not sure if USB tethering would use WiFi over 3G but I dont see why it couldn't :confused:
Was wanting to setup hotspot, in other words use phone as my router, but on KitKat only allows data through hotspot, I see an app FoxFi but haven't tried it yet.
I don't think any phone regardless of OS will connect to a wifi network while at the same time acting as a hotspot. You're much better off using a travel router which can do something like this.
So you want to connect to a wireless network, and then share that wireless network using a created hotspot? That doesn't make any sense.
So why can a phone wirelessly tether data and not WiFi?
Because the wifi controller on phones are only designed to do either of the two one at a time, not both like wifi repeaters. You need something a bit more specialised for that sort of thing. If phones had the ability to do this anyway it would drain the battery pretty fast. The reason why they can do it with data is because the data connection is managed by a different controller.
Shame the reviews for the app seems to show it only activates the normal hotspot function :p. A lot of complaints it only works for data connections.
