Rumour has it that the Polaris 10 refresh will hit very soon. On that note, Bethesda and AMD have done a fair bit of advertising as to how Prey is optimised for Vega. Prey is releasing 5/5/17, it would be pretty odd if Vega wasn't available at the same time.
OMG that stupid reference cooler again...
Hmm, the last die shot only shows two HBM modules; and HBM2 is 4GB a module.
as far as i know it depands on the Hi stack, HBM2 can have 4GB or 8GB per stack, depanding on on the Hi stack chosen of 4 or 8, so 2 stacks can be 8GB or 16GB, my guess reference Vega will be using 2 and 4-Hi stack for 8GB.
the 4GB version would be 1 stack of Hi-4
i dont know the freedom AMD would give AIBs, if they can put 2 stacks of Hi-8 that would give them 16B of HBM2, but my guess 8-Hi stack must be much more expensive, so the premium could be significant if any AIB thinks it's worth it, if Vega is oriented value perf/$, i doubt any AIB would risk it, but if by any miracle it takes performance crown over 1080Ti, a premium 16GB card becomes more likely to happen.
or go 8GB HBM2 + 8GB GDDR5X, since AMD already said that Vega was a hybrid GPU compatible with both memory, although sounds less appealing than full 16GB HBM2
