High Quality Metal Mini ATX Case?
18 May 2006
Can anyone recommend any well build mini ATX cases? Most of the offerings seem to be a cheap plastic / metal combo?
matx cases do not have much offerings they are not big sellers look towards mitx and atx if you want full metal also check out the aluminium cases
If you can wait a month or so, new/revised Phanteks evolv mATX case should be in stock with ocuk
I'm not too fussed actually - the other consideration was actually how portable it was if that helps the suggestions - the phanteks case does look pretty good though
Have you seen the DAN case?
The upcoming glass Evolv MATX is a looker for sure, but it's all but certain to suffer the same issues as its predecessor and big brother Evolv ATX in respect to cooling. It is not very well optimised with that top panel choking it somewhat, and limited intake at the front. It's hardly going to cook your components, but if low temps are a priority it may be a very frustrating case to own unless you were prepared to mod it.
Amazing.. I hadn't but thats the one! thanks for the link :)
