Which OC bundle?
29 Aug 2010
Cornwall
Hi,
First off I should point out that I seem to be pretty unlucky when it comes to the silicone lottery. Or at least, not lucky. Which combined with my very basic overclocking knowledge means I usually don't get great overclocks.
So I've been considering these OC bundles:
https://www.overclockers.co.uk/giga...-gaming-bundle-limited-edition-bu-02k-gi.html
or
https://www.overclockers.co.uk/8pac...-bundle-intel-i7-7700k-4.80ghz-bu-006-8p.html
So my questions are:
1) Is the 5GHz OC bundle worth £140 more?
2) which motherboard is actually the best? I had heard that the Gigabyte board needed a BIOS update to fix some temperature thing? Has that been done?
Or do most chips overclock to 4.8GHz and overclocking is now so easy even I could do it (ring multiplier and voltage is where I stopped fiddling on Haswell)?
Cheers.
Hi,
or
Cheers.
tbh although 7700K is on top now ryzen would set you up much better for future.
what are you doing?
Gaming?
Creative?
you would easily get 4.8ghz on every chip so may as well just buy a retail boxed cpu and save some money.
Is it that common? Last Intel chip I got was a 4770K and mine only did 4.3GHz (with my basic OCing ability), so 4.8GHz seems high.
what are you doing?
Gaming?
Creative?
Gaming. Maybe a little bit of video encoding now and then.
well if you plan to keep this for a good 2-3 years More cores/Threads the better to be honest
I would not been spending that much on Quadcore now days. Its Outdated technology.
Encoding will be faster on Ryzen or X99
Gaming will be slower on some games on Ryzen/X99 now
but soon it will kick in.
https://www.pcgamesn.com/amd/amd-ryzen-7-1700x-review-benchmarks/#benchmarks
check out the graphics performance section.
http://www.gamersnexus.net/hwreviews/2849-amd-r7-1700x-review-odd-one-out/page-4
id be getting this:
My basket at Overclockers UK:
Total: £663.47
(includes shipping: £10.50)
half price almost, 8 core 16 threads vs 4/8 threads
Faster at encoding or any multi tasking
id be getting this:
Total: £663.47
That all seems to point to the 7700K as the better gaming CPU. Price-wise they seem to be very close, motherboard is basically what will make the difference, except I can re-use my current CPU cooler with a 7700K but need a new one for Ryzen.
Although to be honest there is a bit of me tempted to get a Ryzen setup as well as the 7700K.
7700K wins now yes, but when games (including now) becoming more Multithreaded will you want to upgrade again when your left behind? ;)
depends on how long you keep it
my view (x99 owner even considered ryzen)
if 1-2 years go 7700K
if 2-5 years ryzen for sure
or consdider this:
Total: £833.06
(includes shipping: £11.10)
best of both
I did consider that, but would want the 6900K which is much more expensive. 6800K doesn't seem like a big enough difference from my 3930K.
nor would a 7700K at that point
7700K is performance now,
6800K is perf in the future
take your pick..
well, 7700K is performance now, 6800k/Ryzen is potentially performance in the future. We don't know for sure that it will or how soon.
I do get what you're saying and it's why I considered the Ryzen in the first place. I think what worries me is that Ryzen is still a bit of an unknown and has some teething issues (as I understand it). 7700K has probably ironed most of those out now.
