Wouldn't a leaking pipe be Bernoulli Equation as opposed to Reynolds Number?
Only if you join too!Get a room![]()
Yes terrible stereotypes there in the OP. I'm a mech eng and quite happily do anything practical unless it needs certs for legal reasons that I don't have.
However as has been said myself and other engineers tend to excel at the design of things or processes.
Quite often off techs in the past I'd have them ask 'whyd you design that bit' or say 'that's over engineered' then have the same guy a few months later come back with 'ahhhh I see now'. And these are smart guys to boot.
One example being a fairly complex bypass and valve arrangement on a pump system. Worked a treat because in the case of a multiple pump failure there was no down time in switching to an aux pump from another system with minimal cross contamination of fluids.
That's what I used to do. I now have a very...unique job. I'm now an 'aquatic engineering consultant' to give my formal job title!Go on, spit it out. What exactly do you do?
So... I work in Engineering and have many 'engineers' (electrical, chemical, civil, automotive, mechanical) as friends/acquaintances who either have degress, PhDs, or are even chartered status in their field. Yet I find the following trends (for the most part):
Electrical engineers would call a sparky to carry out wiring in their home.
Chemical engineers always rely on a plumber to service their heating/hot water system.
Civil engineers would need a 'builder' for even the most basic construction work i.e. building a wall.
Automotive engineers require a mechanic to service their car.
Mechanical engineers would need all the above for everything.
In theory these jobs should be 'water off a ducks back' for such highly qualified people. Why do you think it is that they have such limited skills in tasks that should be rudimentary for their given profession?
