 - 27 Jan 2012
 - The king of the north!
Hey there everyone i hope your all well!
I have always been under the impression that as you raise resolution you push your systems "bottleneck" further and further onto the gpu.
I currently run a 6700k @4.7ghz with a GTX 1080 and 16gb of ram. I intend to expand the ram to 32gb as im often seeing myself sat at 14+gb when running certain games and believe a little bit of my stuttering/frame drops may be coming from this. I also intend on getting a 1080ti simply for the added vram, as in the likes of star citizen @ 3440x1440 i am capping out the 8gb vram on the 1080.
I am curious however in regards to Zen and if it would be worth considering. As far as my knowledge goes it shouldn't be a worthwhile upgrade however if im wrong i can certainly consider the jump.
TLDR: Would i see any tangible gain from moving to Zen at 3440x1440 over a 6700k @4.7 or will it just be a side grade?
Any input/suggestions welcome.
