Hi all,
I recently bought an MSI 1080 Ti GamingX but am having problems with the PC shutting down. The thing runs hot, really hot! So much so that my entire case was very warm to the touch. I have what i would consider decent air flow. 2 fans on the front as intakes, 1 on the top, 1 on the back as exhausts. The slightly strange thing is, the GPU hovers around the 75 mark under load, but the card as a whole is extremely warm. To the point where you can't touch the backplate its that hot. Another thing i am slightly confused about is the GPU clock. I installed Afterburner to monitor temps and the GPU clock ingame is 1949Mhz. I was under the impression it boosts to 1657Mhz? I haven't overclocked or played with any settings, everything is completely stock. In an effort to try keep things cool, ive been running with my case sides off and even limited the FPS ingames which makes the GPU use only 60% underload. Even with this, i still experience the PC shutting down. Do you think this is a returns job?
PC Stats for reference:
7700k with Corsair H80i v2 cooler
Corsair HX1000 PSU
MSI Z170 SLI Mobo
Many thanks
Corsair HX1000 PSU
MSI Z170 SLI Mobo
Many thanks
