- 18 Oct 2002
- Cheshire
While breaking glass is trivial, most burglars wont want to do this due to the noise it creates. There will be the exception though.
It always comes down to the same argument.
"Windows"
So how is my example extreme? The argument literally suggests if you have windows there's no point in any security. It's ludicrous.
But you can apply that logic to anything. If you've got windows, why bother having a front door?
No you can't apply that logic because you're making an extreme case in your argument and framing it as if I'm making an extreme case.
When I say the burglar doesn't HAVE to deal with a lock I'm talking about as you say, spending a couple of hundred quid upgrading your lock from standard.
...and then someone is able to open the door anyway without having to touch the lock at all because the door or doorframe is inferior.
Or as people have said several times. Breaking glass in a door or window to gain entry is trivial.
So there is a lot of point in not splashing out for the "best" lock when you know your existing lock isn't even the easiest way to get in.
"With the right tools", I can do all sorts to most of what's inside your property boundary... with the right tools...Also I wounld NOT go with ABS Avocet ones at all. The key way is way too big and while these are very nice looking and have some nice antipicking features(trapped pins etc), the lock itself can be easily bypassed in seconds, literally, by using the right tools(semi destructive method).
No, there are no impregnable locks out there. There are plenty of good ones.I HAVE NO IDEA.
I'm lost ....there no good locks out there.
Also in the event of a fire.
Personally I'd always go for a thumb turn.
In our old house we had a key lock on both sides of the door and my other half was *ALWAYS* forgetting to take the key out so I'd have to bang on the door to wake her up so I could get into the house. Also in the event of a fire you're not running around trying to find keys to get the door open.
As for your other points, the first one comes down to the individual and the second is poor planning and frankly you should always leave the keys in the same location each night.
Get Avocet ABS locks, you can order 'keyed alike' sets, so your front and back door can share the same key.
http://www.barnsleylock.co.uk/avocet-abs-mk3-anti-snap-locks-13-c.asp
