So I have had my 5820K setup for just about a year now and haven't had any need to overclock it, but with RyZen now out I was in two minds about upgrading to a 1700 setup. However I thought I would give overclocking my 5820K a go (Below are my current settings)
- Memory voltage at 1.25v
- Memory set to 2666Mhz (was a 2400mhz rated 16GB kit)
- CPU overclock in "all core mode"
- Max CPU multi set to 43
- BCLK set to 100 / auto
- CPU max voltage set to 1.1 (seems to show as maxing out at 1.126 in CPUZ)
With this i can run the Intel burn test fine for multiple runs (on high) and temperature seems to settle at 75c
Below is how the system is running now :
Pretty happy with these results, but does anyone have any advise on improving this setup or any issues that stand out to anyone ?
Thanks in advance
Thanks in advance
