Advice on cooling option
24 Nov 2013
Hi. I'm looking for advice on cooling options for my Titan XP.
I have a Corsair Air 240 case, EVGA X99 Micro 2 MB, Corsair Hydro H100i CPU Cooler and Titan XP. My power supply is 750w.
The Titan does get quite hot so was considering the EVGA hybrid kit but no sure if the fan/radiator will fit in my case.
Similarly I was considering the option of upgrading to a MSI 1080ti Sea Hawk X or even go for an iChill X3 (I know 2.5 slots so would mean making the wireless adaptor external) or an EVGA SC2 or FTW.
Could anyone help advise me which options are possible with the cooling options (Hybrid kit or Sea Hawk) or the AIB's and anything else I need to consider.
Thanks
Pics as follows:-
While the pictures don't help with those angles, my answer is straight forward. Wait for EK new MLC before you make any other decision.
If you were asking before January, when the Predator series went EOL, I would tell you to get a Predator 240 and a prefiled waterblock for the TXP.
Stick them all together and job done.
Same would apply to the MLC with the added bonus, that it will more more modular, so you might fit a second rad if you have space. :)
To put in perspective, my Predator 360 has enough cooling capacity to keep a 6700K @ 4.8/6800K @ 4.2/[email protected] happy and a GTX1080Ti @ 2190 with temps never going over 34C on the GPU. Or a Nano @ 1140 never going over 40C. So you would be OK with the 240mm one if you rung it at around 50-60% fan speed on normal usage.
Benching it will need 100%.
OK thanks I'll probably sit tight and look out for the new MLC
