My new place is a late 1800s property so before I move in I'm going to get a new boiler and radiators fitted as the current ones are around 10yrs old.
I've used an online calculator to work out the BTUs for each room and I'm looking to fit column radiators which comfortably match or exceed the maximum BTUs advised.
Hallway 2675-3200BTU
Living Room 6980-8225BTU
Dining Room 5975-7150BTU
Kitchen 5000-6000BTU
Bathroom 2225-2675BTU
En-suite 2225-2675BTU
Front Large Bedroom 4175-5000BTU
Front Small Bedroom 2025-2425BTU
Rear Large Bedroom 4375-5250 BTU
Loft Room 6875-8250 BTU
Is over-speccing the radiators a good idea? The price isn't much more in the grand scheme of things so is it a case of bigger is better?
Secondly, can anyone recommend a good quality combi which can feed the radiators plus two showers. Ideally I'd like to be able to use both showers at the same time but I understand that might not be possible without fitting a water tank. (Which I don't really have space for)
Would something like this do the job or is a boiler this big just a waste of money?
https://www.ebay.co.uk/itm/272590763008
Boiler room
