Sorry if this is in the wrong section, Not really got the ability to see the forums correctly.
Problem
Using the PC like normal just on desktop (few back ground applications, watching twitch stream, talking on discord) PC suddenly turns off. When I try turn it on, Mother boards lights up, Fans spin for about a second and then its like its in its shutdown state. (Same thing repeats if i press the button again).
System
Intel i7-6950X Extreme 3.00GHz (Broadwell-E) Socket LGA2011-V3 Processor - OEM (CM8067102055800)
Asus X99-A II Intel X99 (Socket 2011) DDR4 ATX Motherboard
Silverstone Strider 800W 80 Plus Titanium Modular Power Supply
Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit (CMD32GX4M4C3000C)
Intel 750 Series 1.2TB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW012T4X1)
Samsung 950 Pro 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive
EK Water Blocks Predator 240 All In One Watercooling Solution - Revision 1.1
Solutions Attempted so far
Removed all but 1 Ram (Same effect)
Removed all Ram (Same effect)
Removed Graphics Card (Same Effect)
Removed PCI-E SSD (Intel 750) (Same Effect)
Removed PCI-E NVMe SSD (Samsung 950) (Same Effect)
Made certain all wires are secured.
Tried OLD PSU, failed
Tired current PSU in old PC, worked successfully.
Removed CMOS batter for 10 minutes and tried again, No change.
Not sure what's next to try.
Problem
System
