Oh. I thought you'd found the S7 Edge significantly cheaper given that's the phone you mentioned then you said a budget of £400Well yes the S7 is about £480
Sorry yes..bit misleading, was meaning given around that range.Oh. I thought you'd found the S7 Edge significantly cheaper given that's the phone you mentioned then you said a budget of £400![]()
