I removed the two front 140mm fans from my Evolv today in order to replace them with quieter 120mm fans but the spacing for the screws simply dont line up.
I've tried fitting an NF-F12 and an Akasa Apache 120mm and neither one lines up correctly. According to the product description the case is definitely meant to accommodate 120mm fans.
[Edit] The other problem is that there is nothing for the screws to actually screw in to for 120mm fans so god knows how Phanteks expect people to use 120mm fans.
Anyone else had trouble with this?
