Having the graphics card saves you a few quid and all these will play the game medium or high according to Game-debate: can I run it feature. Intel are generally better, but it comes at a price. The top one is skylake, the middle one is haswell and then FM2+ for amd.
The bottoms 2 leaves some change for an os if you require one and anything else. Best of all you can get a decent size SSD in the budget rather than a 1tb mech drive.
well i looked at the 4400 version and put it in the game debate and suggested low settings as that was greyed out meaning it was the weaker link and that was 1080p(have to sign in to adjust resolution), mean the site is very good, but my system in sig suggested my gtx 750 be no good for now mans and while its lower than 1080p it runs on medium just fine with the occasional stutter, so the G range could be doable.
the game isnt released yet, but these are the requirements, copied from steam as it was easier.
MINIMUM:
OS: 64-bit Windows 10 / 8.1 / 7
Processor: Intel Core i3-2100 (3.1 GHz) or equivalent
Memory: 3 GB RAM
Graphics: 1 GB AMD 5570 or nVidia 450
DirectX: Version 11
Network: Broadband Internet connection
Storage: 32 GB available space
Sound Card: DirectX Compatible Sound Card
RECOMMENDED:
Processor: Intel i5-2300 or equivalent
Memory: 4 GB RAM
Graphics: 2GB AMD 7970 or nVidia 770 or greater
DirectX: Version 11
and from the Game-Debate site as their inbtween spec
