Windows 7 Pro x64 - unsupported hardware??
5 Nov 2014
turned my PC on today and had a message to say there was some updates so installed them.
after rebooting my PC and the updates being applied I get this message pop up
How can my processor be unsupported hardware but then be ok to work on the latest version of windows?? (im guessing its referring to W10)
My current system is a I7 950, 6GB of ram, Nitro 390 Asus X58 mobo and 2 x 250GB SSDs.
now I did do the W10 upgrade and can install this if I choose too but I had far too many issues with it which is why its back on Windows 7.
edit.....
just clicked on the learn more link (below)
https://support.microsoft.com/en-gb...orted-together-with-the-windows-version-that-
and it seems like Microsoft are now blocking old hardware from Windows update not just Kaby Lake and Ryzen processors!
quote below as to the "cause" of the issue.
This error occurs because new processor generations require the latest Windows version for support. For example, Windows 10 is the only Windows version that is supported on the following processor generations:
For a change I'm with Microsoft on this - why should they support hardware released after mainstream support has ended? If you want the latest hardware, you need ot use software that is suitable too. Drivers are produced by the hardware manufacturer, not microsoft so again not their issue?
