XBOX Wireless Controller for windows 10 Advice please
Don
18 Oct 2002
Wargrave, UK
It depends on which version you buy. There is a boxed version that has "For PC" in its name that comes with a dongle. The normal Xbox controllers do not but you can use any BT dongle AFAIK.
31 Mar 2016
Moonbase Alpha
What happens when you pair the controller to the PC? What goes pfft about it?
I use a DS4 via bluetooth just fine with my PC, the software makes it masquerade as an Xbox controller, it would be ironic if an Xbox wireless controller performed worse.
OP
10 May 2012
North London
Well the pc shows the controller as paired / connected but thats about it , are there steps I should take and steps I shouldnt bother with, My gaol is to use the controller wirelessly for one or two games thats all I want to do :)
