Poll: Poll: Do you have a soldering iron?
Do you own, or have access to a soldering iron at home?
  • Yes
    Votes: 382 78.3%
  • No
    Votes: 106 21.7%
  • Total voters
    488
yes but not very good at it - only used it in the past to make a few hifi cables and stuff.
This probably best describes me too... I wouldn't be that confident repairing a small and complicated PCB (though if it was already knackered I'd give it a go) but ok with a kit, soldering plugs to wires etc
Don't own one (although keep wishing I'd bought one - although at least have access to one at work). Not great at it, but can do a passable job at it.
Yes to having one, no to being confident using it!
That said, on Thursday I had to replace a part on a ~£80K laser marking machine at work, thus far seems to be ok!!
although mine has some bits of melted plastic on the casing...
Mine has my name melted on the front. Directly above that, there's someone elses name melted on the plastic which has been scribbled out.
I *ahem* borrowed this when I was working in a factory. Clearly it wasn't mine to start with due to the fact I crossed another name out.
I've just been looking at the sponge, mine has actually had it now because when I just wetted it, it really did start to fall apart and the spares I've got stacked behind are real cheapies from eBay (pack of three delivered from China for a penny) and aren't the right size. Weller sponges are expensive but I suppose when I look at cost/year, they're not too bad. If I buy another one new, it'll probably outlive me.
Inspired by a comment from someone on Twitter who I assumed would have a soldering iron but when questioned said "I never learned to solder".
Do you own a soldering iron, or have access to one at home?
Secondary question (no poll), if so, are you confident using it?
Can I come round and borrow your one (and thus be able to answer yes to the poll)?
Learnt to solder at school and am not bad at it, if a little out of practice :)
I certainly do. Basic one and a roll of solder. Actually brought a motherboard back to life by removing and soldering a capacitor onto it.
I've got a Hakko 936 clone (Yaxun). It's decent enough for my limited use, only falls down for me on build quality, especially when compared to the Weller ones I've used at work. It's nice to have good temperature control for so little cash, and it reviews decently compared to some other clones. I've used it quite a few times, fixing knackered consoles/accessories mainly, I find it strangely therapeutic.
Soldering is a part of my wider job description, and we did quite a bit in training, but outside of that I could probably count the amount of times I've had to use one in anger on two hands. Now I've moved roles if I'm near an iron something is very wrong :p
yes (well technically it is at my parent's house somewhere)
and yes - didn't everyone learn how to use these at school?
