Fence on top of wall suggestions
7 Sep 2008
I'm Looking to make my home feel more secure
The length of the wall is almost 4 metres long, I was thinking getting some trellis 1 metre high but it is see through and will not provide the privacy I am seeking.
I want something where nothing can be seen through and inexpensive
This is what it looks like currently:
how would a 1 foot panel look on top of that? suggestions welcome thanks.
p.s want an appropriate gate too!
easy enough to mount some short posts using metal fence post shoes screwed to the top of the wall, my only concern would be if it is a windy spot you will put quite a force through the top of the wall.
lol at vulcan
so that's what I'm worried about the wall coming down with the fence in windy conditions
building the wall up would look horrible and be expensive.
how heavy are these panels?
If your serious about panels you want to mount some decent timber to the wall, 3x3 or similar, and the panels in between.
The timber you should mount right down to ground level or just above so its spreading the load across the wall. The wall needs to be sound though, but it looks fairly new or has the end been patched up?
it is an old wall just patched up at the end recently.
how many bits of timber on a 4 metre length would u suggest?
as said above, really you would want to attach posts that go all the way to the ground, a "bit" like this
that looks good my problem is that some of the ground below is actually filled with concrete and it looks like you've put those posts into the ground.I'd be unable to do this
you could bolt the posts down to the concrete with something like this
then also bolt the post to the wall, so the full wall is taking the load rather than just the top
You wouldn't need to, thats quite a fence compared to the wall height. Your talking a bigger wall and a smaller fence. Ratio!
Just a thought, but as there is ivy growing up the wall, why not just build the wall up a bit? You will soon cover it with ivy again so the appearance isn't significant.
It's the cost mate I will need to get the bricks + materials then I will pay labour for someone
I'm sure a fence is a cheaper option and looks nicer. I'd actually like to keep the ivy too.
A shadow box fence could reduce wind load, it's what I'm considering putting on top of my rear garden wall with those bolt down post holders on the top of the wall.
if you are keeping the Ivy anyway, you could go with your original idea of adding a bit of trellis, then allowing the Ivy to grow over (giving privacy).
that'd take a long time though and it won't give me instant protection from the neighbours nuisance
would it be less heavier though?
its not really the weight you need worry about, its the fence catching the wind.
trellis and ivy would allow "most" of the wind to pass through
Quite a good call that, they do reduce the wind impact a lot I hear.
If the wall is maybe a little iffy and with the ivy to grow over it makes sense
What we dont know is how good psd99 is with a saw and hammer ;)
