Hmm strange, mine are alphabetical?The thing that is bugging me, how can I order my favourite contacts, they've imported from google in a random order and I can't figure out how to rearrange manually![]()
Anyone have issues say with inbox and receiving emails when the phone is on the always screen?
Just had it again this morning, I looked at the lock screen and no email notification then within a few seconds of logging in I got an email that was sent at 8am.
I've checked the battery setting to make sure it's not putting inbox to sleep so is there anything else?
Sorry yes mine are but can you order them manuallyHmm strange, mine are alphabetical?
i moaned at carphone warehouse when i didn't get my phone 8 days early like they said, i got it 7 days early. Anyway, i got credited £25![]()
Oh right lolSorry yes mine are but can you order them manually
The Earphones - I've only put them on for about 10 minutes out of curiosity and can say the following compared to my ie80s which as some of you will know are still within the top5 best earphones available on the market (£300+ RRP for those who don't know and have only been known to be bested by £800 grados until not long ago). The included pair seems a bit over zealous, it wants to do everything and hit every range but seems to struggling a bit. It has good range compared to the basic stuff you used to get and I would say it's got good highs and mids - very clear sounding. They do lack on the lows and base department so if you're a fan of big bass then you might need to adjust your equalizer or look elsewhere. Keep in mind that this is in comparison to top range earphones and headphones - I'm sure they're adequate if you've never had an £80+ pair.
Correct me if I'm wrong but they do seem to be noise cancelling pair and the noise cancelling seems to be good and unobtrusive (no hiss). I really could only tell by snapping my fingers next to my ear and have not been able to hear it. They do also seem bit loud. The sound reproduction does leave a bit to desire but again, this is comparing to some of the best on the market. Unfortunately I don't have a £9.99 pair to compare but I did have a 2yr old £25 pair of noise cancelling ones that had to be charged and would say that the "sky are better overall. Usually good earphones do take about 2 weeks to break in so these could end up better. I'd rate them 3.5/5 (with ie80/grado being the 5/5+ mark and low end shure etc around £100+ Mark being 4/5). The non tangle cable is also nice and you can control music etc from it which is bonus.
That's all I can think of for now!
Damn themOh right lol
I can't see any option although I have a feeling this used to be possible on the S6 Edge from what I remember. But that had recents, favourites and contacts in separate tabs I think... this seems to be missing the favourites tab as they've merged it with contacts
Damn themmaybe they will update it
OUCH! Hurt to read thatWell I've cracked my s8+ dropped it on the corner last night. First time I've broken a phone.
Same position as you but I never moaned just got a text message from them to say I had £25 credit waiting.
Same here, got a text message from them re: £25 credit (within 7 days?) for my in-store account which I didn't open.
Anyone able to help with some comparisons / troubleshooting please?
GSam is showing about 3.8% drain per hour with relatively light use (phone is mainly just sitting there doing nothing).
Anyone want to download please and see what their drain is like for comparison? Seems a bit high but I can't work out what's causing it, or if it is regular.
Thanks!
https://play.google.com/store/apps/details?id=com.gsamlabs.bbm&hl=en_GB
Anyone got the clearview standing case? I'm tempted for the stand
Doesn't it tell you what is using the battery? I use AccuBattery Pro (costed a pound o something) and it tells you how much battery each app has used in each session.
