According to their update on Guru, they also feel it is true, so not sure why you are getting so irate over someone posting a possible leak, true or not!
So let's sum up here. Guru now thinks that's true.
That means this "Vega" card is 6% faster than the stock Fury X according to their original post.
This is when clocked 1200mhz vs 1050mhz.
So that means Vega has regressed in IPC.
We know the Instinct MI25 which is Vega has 12.5TFlops. That means it has a clock speed of 1500Mhz, and it's a passive air cooled accelerator just like Tesla.
We know HBM2 is rated for up to 1000Mhz, that's for 1.6Gbps and 2.0Gbps modules, which are the ones AMD will be using.
NVIDIA are using 1.4Gbps modules, which are clocked at 715Mhz.
Yet "Vega" in that Time spy link shows memory at 700Mhz, which is slower than the slowest available HBM2 modules.
The Vega die is almost the same since as Fiji, while the former is on 14nm compared to 28nm.
So Vega is a much larger chip.
So apparently, gaming Vega, which is going to be Water Cooled as a premium part, is going to have under 10Tflops, and be significantly slower clocked compared to an air cooled server part.
While having somehow lower clocked HBM2 when using the higher bandwidth and higher clocked modules.
All this, and then despite Vega being a larger GPU, and all the architectural improvements means Vega has severely regressed in IPC and overall performance compared to two year old Fiji.
That doesn't add up for me.
