- 1 May 2013
- M28
Can you show me that the information is accurate?
Though the onus was to disprove it. What concrete irrefutable proof is there that this is fake? Please submit a counter benchmark
I don't think it is useless unless someone can show this informatiom is fake.
Which nobody can. Only that it doesn't line up with people's prior expectations of a massive IPC improvement. In fact I would bet against one given all the information from the last few months. I can be hopeful there will be one, but that is all it is.
I really doubt this is a fake benchmark. Yes it might not be as helpful as a full review, just like the cherry picked Ryzen benchmarks we got before release, but its infirmation nonetheless. Ryzen did end up being pretty damn good.
If it is a 'legitimate leak' of a Vega chip, without context it ends up useless anyway. Cut down/engineering sample/features disabled etc, we don't know. Whether it is fake or not doesn't end up mattering.
Hardware ID identifies the card as an RX Vega and it has been run on 3D Mark which does basic checks on fake results.
TPU have identified the same specs separately.
Over to you.
We wouldn't be having this conversation if the results blew the gtx 1080 away.
Just like the Polaris ones where they were matching GTX 980Ti, and they were claiming that Polaris is Fury X performance for 1/3 the price according to WCCFT?
We know how true that turned out.
I agree its not ideal, but when did we on this website start ignoring ES results just because they aren't promising.
Prototype of RX Vega based graphics card scores 5721 points in TimeSpy, clocked at 1200 MHz
Note: The score shown in these benchmarks is not indicative of the final product by any means, as is clear from the massive clock speed difference as well as the fact that this could be a different die being incorrectly read as the 687F:C1. A cut down variant is also not out of the question.
Before I go any further, the clock speed of this sample is a mere 1200 MHz. This means you are looking at a number of 9.8 TFLOPs and not the performance Raja Koduri promised. With a single precision compute of 12.5 TeraFLOPs per second on a GPU with 4096 cores, you are looking at a RX Vega 10 graphics card that needs to be clocked at roughly 1526 MHz. Considering the fact that the already revealed MI25 is passively cooled, it should be able to achieve this mark in due course and even exceed it. The specifications mention the HBM2 stack with 512 GB/s of bandwidth and we already know from the RX Vega Doom demos that the product will have total vRAM of 8 GB. The card will consume 225 Watts of power.
AMD’s troubles with achieving clock speeds the likes of the Geforce GTX 10 series makes me suspect that we are probably going to be looking at an RX Vega that will go, at most, toe to toe with the GTX 1080. Anything else, would be wishful thinking given the evidence given. There is however, one caveat with all of this theorizing. AMD is releasing multiple variants of Vega, and there is a possibility that this particular benchmark is of a cut down chip that is meant to go head to head with the GTX 1070. The device ID used in this case is 687F:C1, and while the first 4 digits are the same, the last digit is actually different from the ID we usually catch: 687F:C3.
We wouldn't be having this conversation if the results blew the gtx 1080ti away.
Original RX 480 leak.
https://videocardz.com/61005/new-amd-radeon-rx-480-3dmark-benchmarks
Seems accurate to me.
This ^^^^
Its from the same Chinese guy who posted 980TI beating RX 480 3DMark results, all you do is edit the GPU identifier in the XML before sending it, you can make it look like any GPU you like, this is so blatantly an ancient Fiji card.
I can't believe we are still debating the validity of a 3DMark result from a known faker, Guru3D like WCCF and TPU are just click baiting, again... they know its a fake just like they knew anything in the past from this account was fake, they still post this crap because they know it gets people sucked in and excited, it results in lots of clicks for their websites.
Is there any real news?
wccftech said:Its been a few weeks since AMD unveiled the new RX 480 graphics card based on the Polaris 10 GPU.
When I read that comment instantly my reaction was
