- 16 Nov 2003
- On the pale blue dot
Hi all,
I'm looking to install a CCTV camera above my front door. The camera comes with a network port on the end and isn't removable without dismantling the camera and no doubt voiding the warranty:
It looks to be built that way as there's a kit that comes with it to make the connection waterproof. The outer diameter is 20mm.
The options as I see it are:
- Drill an enormous 20mm hole through the front wall just to poke the connector through, then fill up the gap with caulk or some kind of washer or gromet. This option doesn't cost me anything but a 20mm hole is huge IMO.
- Drill an 8mm hole and feed through some network cable, stick a connector on the end and connect everything up. This adds the cost of buying a reel of network cable, plus there will be some exposed wiring on the outer wall (though apparently this cable is waterproof).
- As number 2 but make the hole 10mm and stick through some plastic piping first, so the cable itself is protected through the cavity.
