Desk recommendations?
+1 for the fredde used with a ROG 27" and a normal 24" on the monitor shelf, removed that once I changed to 34" ROG. I left the right shelf out so my PC could fit under the desk.
Only have a Dell 27" atm but was looking around at getting a 2nd one as seem some on the bay through they seem to hold their value so not sure if can justify two 27"
How wide are the bottom shelfs the PC sits on?
Ordered one of these bad boys too :)
With the Fredde desk how much gap is there from the monitor shelf to the top? Trying to work out if my monitor will fit with the top shelf in place
The Fredde desk would be perfect for me, however, I don't like that there isn't enough space for a full tower to sit properly on the shelf.
Don't put the shelf in and have it on the floor, What I did as no way a Caselabs was going to fit on the tiny shelf.
I was actually looking for a desk that would raise it off the floor. We have hard wood flooring so the PC is a bit of a dust magnet. You can reduce dust build up 80% by just lifting it off the floor by 6 inches.
