Faulty GTX 980 ti
13 Aug 2011
I picked up a GTX 980 ti very cheap from someone selling it as untested.
The card powers and lights up and I initially managed to get into Windows and download drivers.
Upon reboot, it tries to load Windows and then stops at the below screen for around 30 seconds and reboots. It does this constantly.
Any ideas as to what I can try to possibly get it working? Would re-applying thermal paste help in this scenario?
Cheers
Check the pcb, i had to rma a similar card because a capacitor/resistor blew up. Had similar visual issues to what you did.
Very cheap and 'untested'. Lesson learned :).
Any chance of a warranty claim?
I purchased a similar GTX 970 last year and it arrived in absolutely brand new condition and worked perfectly well. So I thought I'd try my luck again!
Unfortunately this card looks like it has already been tampered with. Warranty stickers have been removed and a screw is missing
I've heard about baking GPU's. Is it a myth or does it actually work?
Gas mark 5 for 30 mins, turning once, until you smell aroma of burning silicon.........or 5 mins in the microwave.
Only kidding, I have no idea, don't try any of the above.
Doubt the reapplication of paste will make a difference as long as everything is currently attached.
I did it to both my 8800gtx cards at different times when I saw similar issues. Both worked perfectly for years after and we're even sold on
The process I used is below -
Remove all plastic that you can.
Roll up some metal foil into several balls (about the size of a Brussel sprout) and then place the card ontop of the balls on a flat baking tray. Make sure the chip is pointing up.
Preheat the oven to around 170 - 180c
Place the tray with the card balanced on the rolled up foil for around 8 - 9 minutes or as soon as you start to smell solder melting.
Take the card out and let it cool for 30 minutes and then check that no parts have dropped off into the tray*. If they have it was in too long or put it in upside-down.
Reattach the cooler and anything else you removed and place back in your rig.
If the issue you have is due to a micro fissure in the solder this gap will now have closed up and your card will work fine again.
Please do this at your own risk, I accept no responsibility of further braking of your GPU.
*Please be aware of the danger of parts dropping off the card if the solder turns to liquid. The reason you raise the card up Is because of even heat distribution. If you lay the card flat on the tray you will create nasty heat spots where the card makes contact with the metal.
Thanks for the prompt reply.
I had a look at the PCB but couldn't see anything out of the ordinary. Then again, I'm not sure what to look for :)
Something like that.
Cheers
never trust "untested" as truly untested...
Why would someone not test a £200 PCIE card? how it is not worth testing an item (the act of testing increasing its price by £150)
it was tested and found not working...
Id only believe it was untested if it was a big seller or low value item, or possibly hard to test for some reason,..
Too late, I already did what you said.
Now you owe me a new graphics card :)
That's great information and instructions, thank you.
I'll give this a go when I get home this evening :)
Just please be careful. The 8800gtx of old may have been able to handle this sort of treatment better but the theory is the same.
Below is some citation for you, do some reading first -
http://www.tomshardware.co.uk/forum/293183-33-baking-graphics-card-oven
https://www.ifixit.com/Guide/Tempor...raphics+card+by+heating+it+up+in+an+oven/2240
http://www.addictivetips.com/hardware/fix-your-graphics-card-by-baking-in-oven/
https://forums.anandtech.com/thread...in-what-situations-would-it-not-work.2451612/
