Ditto,
Once Nvidia support Freesync I'll happily go green again but for now I'm AMD only.
"Could" amd trademark..Let me get this straight: AMD are bringing out a GPU that could be faster than a GPU that Nvidia brought out a year previously.
Yay, go AMD!
hard to say, the performance headroom left for nvidia in 16nm node is 20% performance uplift over TitanXp, 30% over Ti, if they release a 600mm² chip, but that is unlikely seeing how they just released these 2 cards a month ago, they would need at least another 6 months before they dethrone it with another card.With Volta around the corner, Vega isn't even relevant, and i always buy AMD
if volta is being released in 2H 2017 on 16nm instead of 10nm as they were planning, then it would replace low-mid range, from 1050 to 1080, where vega is supposed to be faster.
AMD might have skiped high end with polaris gen, that doesn't mean vega is going to be outdated, especialy if you look at it through performance metric as you seem to do.
Let's not hype this too much, this time.
If AMD manage to come out with a card that will beat an NVidia card, they'd only need to undercut green team by £/$100 to be a sales success. Those thinking or hoping a 1080ti killer will be £400 are delusional. Such a card will be £550-600 easily.
glofo is pretty efficient as long as you dont push the clock way beyond a certain point, where power draw become crazy compared to clock and performance scaling, RX480 at ~150watt, and GTX 1060 at ~ 120watt, that's nowhere near twice the efficiency.
as long as AMD doesn't give in to the pressure and OC Vega beyond what the node allow it to, efficiency should be within 20-30watt from 1080/ti equivalent, 220-250watt for nvidia to 250-300watt for AMD, that's what i am hoping for at least, then if ppl want performance over efficiency they can OC, but AMD shouldn't make the choice for them.
That's not going to happen and I doubt AMD would take up G-sync if NV allowed them to. I know AMD made theirs an open standard but probably because they were not first to release the technology? .
AMD themselves have stated the MI25 GPU is 300w at 1500MHz, and that probably works out scaling Polaris and subtracting a decent performance gain and HBM2 savings. Most consumers wont care that much comparison a 300w Vega10 and a 230w 1080ti. My biggest concern would actually be yields for chips like that. The fastest Vega might be biting on the heels of the 1080ti but quite rare and similarly priced. While a 1200MHz that ics more 1080 performance might be a real bang for buck card.
The Tesla P100 is also a 300W card with less overall performance than the GTX 1080Ti, and less TFLOPs than MI25.
The price for compute performance, in FP64, and double FP16. We know the MI25 has double FP16, we just don't know if it also has FP64 performance that can rival it.
We know it has a higher TFLOP count for FP32 and 16 at least; and both use HBM2.
It'll certainly be interesting to see what AMD manages to do with Vega really; especially if they had to put some proper FP64 performance in there; which could help explain why Vaga is so big for the MI25.
Iyt does have FP64 performance, AMD's released documents show that. Vega 10 has 1:16 FP64 performance, so around 0.75TFLOP compared to the P100 which has nearly 6.0TFLOP. I thought vega10 did have reasonable FP64 support but someone corrected me on these forums the other day. Vega10 and P100 have basically the same Fp16 and Fp32 performance (24.0 and 12.0). The only unknown aspect is if the lower Pascal models actually have packed Fp16 math like the Gp100. Nvidia weren't very clear. Testing shows there defintiely isn;t the performance but it coudl be disbaled at the driver level. FP16 is incredibly useful for deep learning and has some use for gaming (but that has to be coded for).
When you say the P100 has less performance than the 1080ti its not really an apples to apples comparison since the P100 is a dedicated HPC chip, doesn't even have video IO ports. a lot of die space is given over to FP64 support.
Except the rx580 is not really anywhere near 150w:
https://www.techpowerup.com/reviews/Sapphire/RX_580_Nitro_Plus/28.html
234w avergae gaming for th RX580 in boost, 214w in quiet mode.
Performance per watt: https://www.techpowerup.com/reviews/Sapphire/RX_580_Nitro_Plus/31.html
The 1060 is 180% of the RX580, thats close enough to twice. The 1080 is at twice the performance per watt.
My other comparison, the RX480 has similar performance per watt as the 970 despite the latter being built on 28nm.
Yep no chance.
This is why I don't want to buy anything Nvidia due to their business practices.
Been eye'ing up an ultrawide LG freesync great price, just need a card to compliment it.
