Been stressing my new card out today with this and it's all good up to +100/+500. Above those values, the program crashes. Can I take that as an indicator the card isn't stable at those freqs?
Ok that's too bad. I thought I'd see artefacts before CTD and was hoping there was just an issue with Unigine.Yes.
As a general guide, artefacts are normally due to too an overclock which is too high on the memory and a crash/lockup is more core related. Just back off by 13mhz on the core till you get no crashes or lockups.
Gave it a shot, looks like I'm capped at +100/500.
I'm heading the air cooled 1080ti results on Ryzen at 1080 Extreme.
1999MHz seems to be the highest sustainable TI clock on air.
Intel Xeon 2680V2 ([email protected]) Fury X water cooled 1125mhz.
Sadly that's all she will do. Any more and I get slight artefacts and then a hard lock in the last test.
Had a little go myself with my MSI FE ref cooler.
Gpu +162/+432 Cpu 4.3ghz 4770k
Could you confirm your GPU memory speed and drivers used please.
GPU memory speed is stock. So whatever the HBM clocks at.. Drivers were 17.5.1![]()
GTX 670 @ 1110/1502Do you have the GPU clockspeeds please.
Max 2075 and mem 6003.Could you confirm your actual GPU clockspeeds please.
