im looking for a cooler for i7 3770k so I can overclock a little what should I get?
Your case will clear any cooler I know of. ;)
What motherboard and RAM do you have? Because both can cause cooler clearance issues.
As for what cooler, it depends on how much you want to spend.
Probalby the best cooling and decent priced is Phanteks PH-TC14PE for £44.99 or £47.99
https://www.overclockers.co.uk/phanteks-ph-tc14pe-cpu-cooler-silver-hs-000-pt.html
https://www.overclockers.co.uk/phanteks-ph-tc14pe-cpu-cooler-black-hs-009-pt.html
At lower prices there are all kinds of options. While Hyper 212 used to be a great low cost cooler, there are now a bunch just as good or better for same or less money.
Here on OcUK the 212 is 24.95,
At a quick glance we have:
Raijintek Themis 25.99
Raijintek Themis Diret 25.99
be quiet! Pure Rock Slim 24.95
Zigmatek Gaia 16.99
Up the cost a little and we have coolers like:
Alpenfohn Brocken EVO 29.99
Alpenfohn Matterhorn Pure 33.95
be quiet! Pure Rock 30.95
Cryorig H7 34.99​
