- 14 Jul 2005
- Bristol
And, ironically, every time I've been early for a ferry crossing (either Dover-Calais or Dover-Dunkirk or their reverse journeys), I've been able to board the earlier crossing with no questions asked.
Every time I've used the tunnel I've ended up boarding about 2-2.5 hours early without any issues at all just by picking a time when I roll up to the barrier then hopping on the train if my letter is called (even if it's earlier than the one I picked). I only travel on them early in the morning or in the evening though, don't know if that makes a difference?
I've been late for one too, booking was something like 7am, left my hotel at around 6.30am with over an hour's drive to the tunnel, got on the train around 8am.
As for toll roads in France after my experience with them, I'd absolutely run them again (I have a tag to make life easier). Quiet, smooth(er than UK roads) and worth their cost IMO. I happily cruised at 70 without annoying others on the roads but could also bring it up to 80 if I felt like it (I wasn't in a rush), 130km/h limits are great.
E: Also, RHD car on LHD roads is totally fine. Beam deflectors are fine too, if you install them correctly all you'll do is remove the 'tick' from your beam so have a slightly reduced beam range but nothing as bad as is being described.
Oh and with a lowered car, you'll automatically be put onto the lower deck, which is nice as you don't need to faff about with the ramps.
