Done it! Rolled back to an earlier build. Don't know how I missed it 4-5 times I had that window up.as title, how do I do it?
Aquasuite does not work and I forgot to turn restore on and I can't find the update in update history.
Settings- update and security*- Recovery, under the reset windows option there should be the option to roll back to previous build.how did you do it? I'm having serious issues with my colour settings since the update....
Aqua computer now charge for newer updated versions. don't need a newer version yet, I'll have a look if its creator build safe then I'll pay £17 for a licencePester their support to make it compatible.
if you have issues reset (clear) your update history and re try that usually does the job. creators update doesnt like having failed versions of it sitting round doing nothing. then do a roll back.
Problems with windows update
clear the Windows Update history,
1. Open command prompt:
1) Click Start, and then type cmd in the Start Search box.
2) In the search results list, right-click Command Prompt, and then click Run as Administrator.
3) When you are prompted by User Account Control, click Continue.
2. At the command prompt, type “net stop WuAuServ” (without quotations) and press Enter.
3. Click Start, type “%windir%” (without quotations) in the Start Search box and press Enter.
4. In the opened folder, look for the folder named “SoftwareDistribution” and open it.
5. Double click the DataStore folder and locate the DataStore.edb file. Right-click on the file, select “Rename” and type “DataStoreold” (without quotations) to rename this file.
6. Open command prompt, type in the command “net start WuAuServ” (without quotations) and press Enter to restart the Automatic Updates service.
Then check if the updates failure history is cleared
good post and bookmarked for when I need it. there should be a sticky with info like this, I spent hours trying to figure out why windows kept braking after one of my gpus went swimming something to do with having to rebuild mbr.if you have issues reset (clear) your update history and re try that usually does the job. creators update doesnt like having failed versions of it sitting round doing nothing. then do a roll back.
Then check if the updates failure history is cleared.
