I3 3240 and EVGA GeForce GTX 980 Ti CLASSIFIED
29 Jan 2010
London
Hi guys, just bought a gtx 980ti to replace my gtx 770. I had it running just fine tested on some skyrim with no problems but on Mass Effect Andromeda i get 15 to 30 fps on ultra preset. Is that normal? I know my cpu is to week but was expecting 45+ playable. Is there anything I can do? Some setting that are more of a cpu bound? Or do I have to buy i7 3770 to enjoy it? My mob is not overclockable so i cant push my i3... btw cpu is at 100% while runing ME A but on skyrim is 50/70% Any ideas?
no you basically have a CPU thats not designed for games. Normally in your scenario with a K you would just OC the CPU to give you a bit more but you can't.
You either get a decent i5 or i7 3xxx CPU or upgrade your motherboard/cpu
I had been playing with Watch Dogs 2 just to see how it works. I get 35 to 45 fps on all max settings with TAXX x4. So far only ME A is the game that is unplayable. I came to a conclusion that CPU upgrade is needed but that's a discussion for CPU section of forum. Thank you guys for help.
