AMD A8-7600 Series
17 May 2017
Newcastle under Lyme
Is the AMD A8-7600 a good CPU to add my build? I currently have a AMD A4-5300 which came with a bundle i got from eBay.
My build is the following:
ASRock FM2A85X-ITX
AMD A4-5300
EVGA 950 SSC
Corsair Vengeance DDR3 8GB 1600Mhz
Kingston 120GB V300 SSD
WD Black 500GB 2.5"
Corsair HX520W
Thanks for looking and any advice would be great.
The board is limited to FM2 processors only.
Thought it was the FM2+ version - the A8 7600 won't work in either then it seems:
http://www.asrock.com/mb/AMD/FM2A85X-ITX/#CPU
I would probably look at a secondhand X4 750K or 760K though,ie, under £50 and make sure you have a cooler which blows down onto the VRMS.
Edit!!
The X4 750 non-K has a lower TDP so should be easier to cool.
Edit!!
Thanks for the help, i will hunt for a 750K on eBay.
