- 21 Oct 2011
- ST4
Just knit thee sen a pair of wooly gloves. Problem solved.
I dont know about you, but every steering wheel i have used recently has padding and is covered in leather.
Saying a heated steering wheel makes more sense than heated seats is a bizarre comment![]()
Useless, IMO.
It's usually the backs of the hands with less flesh that suffer most from the cold, at which point you just direct your heater vents to cover the 10 and 2 position on your wheel. .
This was evident from having had heated grips on the bike - Even stationary with no wind chill, they could burn the insides of your hands but the outsides would remain freezing. Swapping to heated gloves with the element wires on the backs, hands stayed toasty warm under all conditions.
Ditch the steering wheel and keep below the bracket.
Whether it's worth it in the UK...? Probably not so much!Not so much, in my experience. Not unless your wheel is bare metal? Generally I find the wheel insulated enough that the inside of my hands can start sweating before the backs have fully warmed in the heater airflow.Probably depends a bit on the temperature. When the car has been outside in -30 all night the wheel takes a long time to heat up, moreso than the air around you.
can't say I've ever felt that my hands are uncomfortable on the wheel, or felt the need to wear gloves.
That did not escape my attention, no... Having ridden an unfaired motorcycle in minus double-digit temperatures (it seemed like a good idea at the time), as well as driven a car in them, I felt reasonably up to the task of answering said remark.Did you miss the part where he lives in Canada and it's minus 30?
Its the typical one where people that have or had a heated steering wheel love having it and people that dont or never had a heated steering wheel dont see the point. The same discussion happened ages ago about air con, its the I dont have it so theres no point to it syndrome.
If you can speed up that process (and then turn the heating off) the more the better!That did not escape my attention, no... Having ridden an unfaired motorcycle in minus double-digit temperatures (it seemed like a good idea at the time), as well as driven a car in them, I felt reasonably up to the task of answering said remark.
It's also about how quickly your body responds to that heat. My hands are usually very warm, which is why I can end up with palms sweating from the heat while the rest of my hands are still painfully cold.My wheels are the typical steering wheel material. That doesnt solve the issue of requiring a significant amount of evergy to heat up and conduction of heat being faster than convection and radiation.
Personal preferences and tolerances, I'd guess, then. Same for when you get into a baking car and the wheel is too hot to grip. Either way, I wouldn't expect such temperatures to happen often enough in the UK to justify a heated wheel.We're talking about steering wheels here that even with ski gloves on you have to alternate hands to keep them warm enough until the wheel heats up. Thats the issue I'm talking about and why I'm not sure it's worth it when it's not that cold.![]()
See, I prefer them because the seat heats my core, which in turn warms my extremities better than direct heat to my hands. Never found feet heaters of any use, either.As an aside I hate heated seats, we have them and I never have them on because they make it too warm and I don't see the need, but then they are fabric and lots of air, not a thin material wrapping a metal core.
In the case of heated grips on a bike, no matter how hot the grips get (and you can easily burn your hands on them) they never seem to keep the actual cold out, whereas I find the heated gloves warming the back of the hands (in the same way a car heater does) give a far better result. Best of all is a heated waistcoat, again because it heats your core, like the heated seats.Edit: and I'm not sure how riding a motorcycle is relevant. In a car warm air is contained, whereas on a bike the air around you will not warm up so the only heat you're getting is from the handle.
Can't see pic, no idea what that is, but I assume it's hilarious?
