Mate over the road is changing or was the drop links on rear of his Mondeo Estate - trouble is we can't work out how to remove top fixing - They are not held on by nut -- After trawling net and the tube I finally found a exploded diag which shows that the end of roll bar has a stub on it which looks like the drop link slides on but can't see what then holds it in place - It has what looks like a domed head with no spanner flats or allen key hole. If it is a stub then we can't just angle grind it off - we could if we took roll bar off and drilled out stub and used bolt's - but that's a last resort.
Any one got any better ideas or know exactly how it's fixed on.
