1080ti FE, anyway to water cool it cheaply?
20 Oct 2011
I do not have a custom waterloop in my system and I do not think I will be fitting one.
But is there a cheaper type bracket that can be used on the founders edition or the 1080ti that a standard AIO cooler could then be attached.
Or is that never going to happen?
TBH if you're thinking of water coolling just do a custom to start with. Will pay dividends in the end
That and the fact GPU blocks cool the mem/vrm's too. Tthe universal ones i've seen just do the GPU
If on a budget just buy a corsair h55 and a kraken G10 (assuming it fits a 1080Ti, read some reports it does)
I've got a 980Ti on this setup but I went to town a bit and got a noctua fan and added some custom made heatsinks to the ram chips etc. Works like a charm and cost about £65 all in (bit more for me with the subbed in noctua fan, but you don't need this).
I've got a 980Ti on this setup but I went to town a bit and got a noctua fan and added some custom made heatsinks to the ram chips etc. Works like a charm and cost about £65 all in.
Sounds good, I watched these 3 YouTubes videos earlier that shows how to use a evga hybrid kit with the original shroud.
So perhaps the 1080 kit might be reduced soon or cheaper.
Part 1
Part 2
Part 3
