just a quick one,
I've noticed a chip out of the sidewall of my tyre, i am going to Birmingham next weekend and would prefer to feel safe. there is plenty of tread but if its a serious issue i would rather change it.
im getting a new tyre soon on the rear as the tread has gone on one side and i think it needs alignment but the tyres offer a £10 off for 2.
if i do would i be best getting both the new tyres on the front? (front wheel drive B Max)
EDIT!!!!*
I have decided to order 4 new tyres, im going to replace this one and one rear needs replacing leaving 2 i was going to put on the front but one is a no brand tyre with a decent amount of tread and the other is a bridgestone with about 3mm left so rather then have uneven tyres I've decided to just get 4 new michelin cross climate tyres as they weren't much more then the goodyears same noise at 68db but promise better mileage and wet performance then the alternatives.
EDIT!!!!*
