My wife's mini needs new front brake pads shortly (its a 2010 with 44,000 miles). There's a lip around the edge of the discs which feels like its about 1mm. The discs also look very rusty around the edges.
Do I need new discs and pads, or just new pads?
Mini value servicing suggests £259 for new discs and pads and I'm sure they'll say both need both doing.
Wondering if just pads will do the job, I can get some OEM equivalent or better spec pads and get the local VAT registered garage to fit them, so not affecting my Mini extended warranty.
Any advice appreciated
