An example cable - but get the shortest cable you can get away with ideallyWhat's the best way to connect a computer which only has HDMI output to a VGA/DVI input monitor ?
Either way - the outputs on the GFX or monitor would be identical (which ever has the HDMI or DVI).Would it work HDMI to DVI ? or just DVI to HDMI like the title ?
No problem - better to be sure.Thanks by the way
