- 22 Jul 2015
- Aberdeen
The PSU and bottom radiator cover is ready. I dedicate this build to my lovely children and you can see their names on it.
The two rectangular cuts in front are for the temperature display. There is an opening for the gpu cables on the top. It is made out of the 5mm thick clear acrylic sheet; which was bent, cut, painted and etched for lighting up the text and the design.
I will be using RGB strip under this and control it by Asus Motherboard RGB header.
