/]No, that's a Intel board. For Ryzen you need a AM4 board so either B350 or X370. See the range here.
Is it overkill?/]
Ah okay thankyou, I have found this one from the selection: https://www.overclockers.co.uk/asus...ocket-am4-ddr4-atx-motherboard-mb-69e-as.html Is this overkill at all?
Well, I will mainly use the PC for gaming, but I dont really know what is important form that point of view. Any advice?Is it overkill?
Depends what you want from a motherboard yourself?
Do you plan on overclocking?Well, I will mainly use the PC for gaming, but I dont really know what is important form that point of view. Any advice?
noDo you plan on overclocking?
Do you plan going xfire/sli
How many USB/sata/m2 connections do you need?
Xfire/sli is the respective terms for dual card setups of amd and nvidia.no
What is that?
I have no idea, maybe 6 USB ports?
Would you be able to Spec me a good one?Xfire/sli is the respective terms for dual card setups of amd and nvidia.
Given your requirements, IMO, you've no need to be dumping ~250 quid on a motherboard. Getting a much cheaper one would release funds to upgrade other parts, e.g. Gpu, ram, storage.
I could have went with a b350 board myself but went gigabyte gaming 5 (about 70 quid cheaper than the asus you linked) as a 'happy medium' between low end and high end. Means I'll be less likely to want or need a new board if I move to zen+ later down the line.
But honestly given you're above requirements you'd almost certainly be fine with a ~100 quid board.
Alright will do, thanksfrom my own 'investigations' the gigabyte gaming 5 I'm going for is a very capable board and can be hard for about 175 quid or the K5 for about 150.
What I'd suggest you do is post in the general hardware section a 'spec me' listing your total budget and what you need hardware wise. There's some really helpful and knowledgeable chaps in there will help you better. I only researched my own specific needs, those guys will have a much broader knowledge base.
