- 19 Oct 2002
- Shakespeare’s County
It's also completely nonsensical in that usually the small turbo starts all the hard work before the larger one takes over. The small one would be at, if not beyond boost by the time the larger 1st turbo was maxed out.
Or it has a diverter valve to manage the airflow and subsequent pressure delta in order to lower the engine boost threshold and hence give the customer good response.... or indeed the large turbo comes on song prior to the small such that at higher airflow the small turbo compressor is not required to provide any pressure boost.
which is of course exactly what it does do and what OEMs have been doing for years.
Possibly just a typo or the higher flow turbo is simple smaller as it doesnt have variable vane tech./
