8 Jun 2017 at 20:26 #1 yoyo59 yoyo59 Associate Joined 20 Sep 2011 Posts 812 hey guys my brothers swiftech h220 pump is dying and he has a budget of £100 for a new AIO 240mm its been awhile since I knew anything about AIO so thought id get some opinions Thanks
8 Jun 2017 at 20:39 #2 Minibiker Minibiker Soldato Joined 27 Mar 2016 Posts 7,591 Location Bristolian living in Swindon I know its £20 over the budget mate but I had the Corsair H100i in my previous build... it's great! Other than that you could check OCUK clearance section.. they have the Corsair H105 AIO for £90
8 Jun 2017 at 20:57 #3 yoyo59 yoyo59 Associate OP Joined 20 Sep 2011 Posts 812 Minibiker said: I know its £20 over the budget mate but I had the Corsair H100i in my previous build... it's great! Other than that you could check OCUK clearance section.. they have the Corsair H105 AIO for £90 Click to expand... would have to avoid clearance section as he needs the warranty he games a lot I think it would be worth getting new
8 Jun 2017 at 22:46 #4 Brizzles Brizzles Man of Honour Joined 16 Mar 2005 Posts 8,097 Location Clevedon , Bristol https://www.overclockers.co.uk/arctic-cooling-liquid-freezer-aio-cpu-cooler-240mm-hs-06b-ar.html Gets a good review here ; https://www.kitguru.net/components/...tic-liquid-freezer-240-aio-cpu-cooler-review/
9 Jun 2017 at 14:45 #5 Robbie_G Robbie_G Gangster OcUK Staff Joined 16 Mar 2008 Posts 8,028 Location OcUK HQ If you can hold off for a couple of week then the below is an awesome cooler for £90. https://www.overclockers.co.uk/cors...-performance-liquid-cpu-cooler-hs-03j-cs.html
