Hello All,
I have just put together my 1st custom loop, I chose hard tubing as it does look very ... very nice. I am looking at some feedback / advise into improving the loop further.
Some notes :-
1) I'v ran the loop for 20min with some distilled water and there are no leaks
2) After that I drained the water and will re-run a fill / flush / drain tomorrow
3) I know the pipe running from the CPU block to the rad looks funky (ran out of tube and had to make do with what I had left)
4) When draining water seems to get "stuck" in the rad -> pump pipe (any ideas on how to drain that ?)
Some things i'm pretty happy with
1) the radiator -> pump pipe kicks out and around the top of the reservoir and then down into the pump (was a pain to bend but worked out quite well)
2) the pump -> drain port -> CPU block pip looks very neat in person
3) Again it didn't leak
So yeah .... any thoughts / advice would be great
Some notes :-
(Will replace them after I get some more time / tube)
