Hi
What is OV Max limit i MSI afterburner.
I've read on what i can find on the internet that it's Over volt Max limit and as i understand it is the MAX? amount of over volt the graphics can deliver?.
But I cannot understand how it works because of the following.
I've been trying to Overclock my Nvidia 1080. and started with oc'ing the GPU and reached about 2100 MHz. But running it there for extended period of time, well after my graphics reaches 52C i hits the OV Max Limit and clocks down to 2088 MHz.
But here is the odd part. If i Clock my graphics to just run at 2088 MHz when it reaches 53C again and raises the OV Max limit it clocks my card down to 2064 MHz and and again if i set my graphics to 2050 MHz it jumps down to 2033 MHz when hitting the OV Max limit.
Its that odd behavior I cannot understand.
Right now I run my graphics with 2050/5400 where it clocks it down to 2033/5400. but its the point where i get the most out of my graphics.
NOTE: No other limits is hit not the power limit nor the temp limit. my card runs at 55C at the above oc speed.
a side question: when i Tried to OC my graphics memory (without the GPU Oc) i hit an upper limit of 5643 MHz. I couldn't push it any further and no limiter was hit.
Regards Ephreal
Regards Ephreal
It will be interested to see how it performs with a Threadripper 16 core
