I bought a Zotac GTX 1080 in January but have only just got round to using it due to work commitments. Now upon playing Battlefield 1 last night I noticed on the stats displayed by RSS that the core temperature was 92°c. I had a mild overclock of 75mhz on the core and nothing on the memory with the power limit and temperature limit cranked up.
So tonight I have run some tests, I've removed the overclock and set the temperature/power limits back to standard. After that I've run firestrike ultra where it is dropping to below the advertised boost clocks after throttling when hitting the 82°c temperature limit. After re-applying the temperature/power limits but leaving the overclock alone it's hitting 90°c!
I am assuming that it is due to poor thermal paste application, is this grounds for an RMA? As I believe the card was like this from the factory and has seen little/no use can I push for a refund, looking at my rights I think I can but if anyone else could offer insight it would be appreciated.
I've spoken to Zotac this morning who advised that the card even when clocked shouldn't exceed 83-85°c but that as the card is less than 1 year old the re-seller has to honor the warranty. They also advised that should I remove the cooler to inspect and/or replace the paste that the 5 year warranty that swayed me to buy the card will be void.
Finally the card was bought from another re-seller other than overclockers, hopefully I won't have too hard a time getting this sorted and enjoying games again while work is quiet. If I can push for a refund I think I will get another MSI card as my last never few have never given me any issues despite the lower length of warranty on offer.
