Is there different PSU's
27 Mar 2016
Bristolian living in Swindon
Hi all
I have a Micro ATX motherboard for my current build... It has a 4 pin connection in the top left of the board but my PSU doesn't seem to have a 4 pin connector (or I'm being blind) is there different PSU's depending on your size Board?
Not sure how good Cougar units are as there is little info on them review wise. Should be fine for a basic/lower end system though.
You should definitely have a 4+4 cable (Labeled cpu). You can see it in the link below.
https://cougargaming.com/en/products/psus/vtx/
I am going to get the box out as I may have it in there... it's going in a build with a G4560 so not a powerful build
