With my current machine being 5 years old, it's time for an upgrade, and as fun as mATX builds have been, I'm going back to watercooling and full tower, my current spec is:
Lian Li PC-A04B
i5 3570k @ 4.2Ghz
EVGA 980ti
16GB Corsair Vengeance
Asrock Z77 Extreme M
And some Corsair PSU which is lovely. But it's not an ultra silent one.
All of the above will be sold, but price isn't much of an issue with my new build so any extras from the above will be nice. I will be keeping my 2x 4TB and 1x1TB mechanical drives, along with my 3 SSD's, although only 2 SSD's are needed, the 3rd is just not used anymore.
The new case is the Lian Li PC-011, here is a VERY quick spec:
** Do Not link to competitors ** - Sorry! Didn't even think about the competitor links in the build.
CPU - i7 7700k
RAM - 4x8GB Corsair Vengeance LPX
GPU - EVGA 1080ti Founders edition
PSU - Corsair RMi 1000w
Case - Lian Li PC-011 WX
I can't decide on a motherboard! Any advice?
Watercooling, I'll probably go down PETG tubing route, with 2 rads, one on the bottom and one at the top. Not sure if I want a dual loop or single yet... I love the idea of dual, but having 2 pumps running might be a bit too noisy. CPU and both GPU's will be under water, and I'm aiming for silence, so normal web browsing I'll likely have just 1 fan on each rad pushing air slowly. Then when gaming, all fans at a medium speed to keep temps down.
Any thoughts on the build? What should I change? Any new tech coming out that I should wait for?
Thanks!
Lian Li PC-A04B
i5 3570k @ 4.2Ghz
EVGA 980ti
CPU - i7 7700k
Thanks!
