I never bothered overclocking my 5930k or my 1800X or any GPU and performance has always been good. Reviews make it sound like overclocking is needed to play Tetris at 640*480.
Yeah apparently when we are moving off 2560x1440 to 3440x1440, 4K or VR, 720p and 1080p became mandatory resolutions to play somehow. Hell not even my TV can do 1080p atm. Is 4K HDR
and the PS4pro handles it fine. Ahh forgot, maybe need to ask Sony downgrade the device and chop 4 of it's cores to bring it inline with "the mainstream PC"
Exactly this! I posted over in the 7700k binned thread a while back. Even when overclocked to 5.2 ghz the increase over stock was minimal. Like within margin of error stuff. Money would be better spent on the GPU. I'm not saying there isn't a place for it, but once you get over a certain limit you hit very diminishing returns. And it seems that's what intel have done here. That extra speed has equates to almost nothing over the previous gen but has brought a load of heat and power consumption with it.
Back on topic, thread ripper has got this in the bag.
I agree on the diminishing returns.
[email protected] with 5Ghz has no difference in perf. Just generating heat and some benchmarks were better. But real gaming wasn't better. What improved my gaming experience was the jump to 6+ core CPUs.
BF4 and BF1 respond well to overclocks - the difference between my 4820K at stock and 4.6GHz is the difference between ~50 and holding 60fps or more normal with the settings I play with from 80 to almost 100fps making better use of my 144Hz monitor. (This is 1440p).
Granted not all games respond as well especially if you up the res to 4K but you are massively downplaying it even on the cutting edge CPUs.
I can only imagine either something wrong with your setup or you are comparing against a poor overclock.
I had a 4820K. Yes stock the perf wasn't good enough even at 4.9Ghz was running 24/7
Same applied to the
[email protected]. Don't forget the RAM bandwidth is far inferior compared to DDR4 also.
Where I saw big jump in perf when I switched to
[email protected]. Yes my benchmarks went down, compared to the 4930K, but gaming was miles better.
In WOT alone, from 70fps went straight to 90. (2560x1440).
However, buying a 1700X, but due to Asus burning it and no mobos available switched, and 6800K later, even if both are/were merely overclocked to 4Ghz the gaming performance is far superior to all the previous CPUs and fps jumped to 110+ where before was 90. (same card & res).
And I will give a very simple example. World of Tanks & World of Warships using the same single thread game engine. (with some sound process offset to a different thread from time to time).
On the
[email protected] it was running on Core 2. That core was running 90-100% all the time.
On the Ryzen & 6800K was/is running on core 4 and 6 respectively. On both systems OC @ 4Ghz, the core usage never exceeded 60%. (only when I run the 6800K stock hits 72%).
In the mean time, in the system I always have running TS, because of the clans, internet broadcasting (Addictive 90s), and few tabs open on second browser for quick alt-tabbing which is SMOOTH and without delay compared to the
[email protected]. Most of the time Steam & Uplay are running on the background also.
Some could complain that I run too many apps on the background, but isn't what PCs are for? Why restrict myself to 4 core CPUs, where all processes are pact in 4 cores, and what ever is left over to their threads and not spread them to 6 or 8 cores or even 16 cores now they are becoming affordable. (16c TR will go for around £850 given that the server part is around $700!!)
Hell, I will be able to even make faster rendering with the Unity 5 now in the process, with a machine that won't break the bank, and can use it for other things than just rendering. (tried a xeon and handed back, cannot justify the costs and uselessness on general usage).
And yes I can live with 110-112fps at 2560x1440 on World of tanks & Warships with freesync (or atm without while playing with a GTX1080Ti). I do not want 200 a 5Ghz 7700K might give me, because I will have tearing
(muahaha)
