ES File Explorer Replacement
7 Aug 2012
Hi All,
I'm after a replacement for ES File Explorer as it just seems to keep having more and more bloaty crap added to it with every release.
The core features of the app tick every box I want, however all the useless extra stuff is getting too much now.
Has anyone made the switch?
Cheers
Swain90
It's not very intuitive. From the Storages section tap the 3 dots, then Storage Manager, then the + in the clrcle at the bottom of the page and take it from there. You will often find yourself lost when copying files from one drive to another or to another device.
I've got the paid for version of Solid Explorer and use my modified older version of ES Explorer by choice.
Much better use of money to buy solid explorer than ES pro. ES pro is just an older version of the app and it doesn't really get updated.
+1 to Solid. I like the UI which you can customise and it's very Material UI. You can flip the phone to landscape and then have two panes which makes copy/pasting pretty easy. Have all my cloud storage (Google drive, onedrive, dropbox, etc) added as well and is easy to access.
I also have the FTP addon which allows me to access the phone from my PC wirelessly.
